Waterfowler41
How to remove the factory exhaust WITHOUT cutting and install the Kooks catback system on the 2019+ Ram 1500 trucks.
I bought this kit for a few reasons. First and foremost, its T304. I have owned several 304 kits in the past and swear by them in the salt belt. These kits last. Yes 409 will do ok, but the surface rust can be an issue down the road when you want to remove the kit. This kit also retains the factory front resonator and OEM exhaust tips. Haven’t decided on what route I want to go with the tips (Carven or Mopar) but I have options. Lastly, this is Kooks’ “street” kit so sound should be a little milder than some of the straight through kits.
I purchased the kit from Realtruck.com and received it in 3 days. This blew my mind because previous kits I’ve order from other places took weeks to arrive so this was a pleasant surprise. My SW systems for my GMC took 6 weeks to arrive…
Kooks Catback.
This video shows the installation as well as before/after sound clips. Step by step pictures are below:
Enough rambling, let’s dive in.
Kooks Catback.
- Spray every rubber insulator and clamp from the muffler to the rear of the truck with WD40 to help things loosen up.
- Unbolt the factory exhaust tips using a 13mm socket. The Kooks kit reuses the OEM tips so clean them up and set aside for reinstallation.
- Unbolt the clamp holding the passenger side tailpipe together. The clamp is welded to the pipe so you only need to loosen it. 13mmm socket as well.
- Remove the passenger side muffler from the rubber isolator. Support muffler with a jack stand or a buddy (bonus points if his name is Jack).
- Using a dead blow hammer or a 2x4 and hammer, gently tap the front of the passenger side resonator to help it slide out of the y-pipe. You should need much for to get the pipe out. Once out, set the pipe aside and prepare for the fun part.
- Remove the spare tire.
- Remove the driver side heat shield that surrounds the spare tire. (3) 10mm bolts. Be careful, there isn’t anything holding this on so once its unbolted it will drop.
- Unbolt driver side lower bolt using an 8mm socket and an 18mm wrench. Move link out of the way so when you lift the truck, it doesn’t get caught.
- CAREFULLY jack up the driver side of the truck by the FRAME. This will lift the body of the truck but leave the axle on the ground. IMPORTANT: watch all the wire harnesses and brake lines so you do not over lift.
- Unbolt the muffler assembly from the factory mid-pipe. Also, remove the ground strap that is clipped onto the muffler hanger.
- Unbolt the two nuts that hold the silver hanger bracket (located above the muffler with orange isolators) from the truck frame.
- Remove the driver side resonator from the rear hanger. At this point only the two studs above the silver muffler bracket are holding the exhaust in place.
- With one person under the muffler and another near the driver side rear resonator, start by sliding the whole exhaust system towards the rear of the truck to clear the bracket studs above the silver hanger bracket.
- Next start passing the exhaust kit over the axle to the person who was under the muffler. The kit will need to be rotated slightly in order to clear the axle, gas tank, and various wires but should eventually slide out from under the passenger side of the truck.
- Now fist bump your friend, the hard part is over.
