Granite2WD
- Dec 8, 2019
I have a rattle in what I think is the dash speaker on the driver's side. Is this easy to remove and inspect or should I go to the dreaded dealer?
Thank you so much!! I used a plastic paint scraper to pry off the cover very easily. I saw three screws, the most rearward of which was loose enough that you could wiggle it and make noise. I tightened it, but it almost felt stripped. I left the cover off to drive and listen for it. I appreciate your help!No. No dealer for just that. Little tiny screw driver you can pop one corner of the speaker grill up, then remove with hands. Speaker is held in by 2 screws diagonally situated. Might be that one is loose. If so use a stubby Phillips.
Hmmm....there should only be 2 screws. Do you have Alpine or HK?Thank you so much!! I used a plastic paint scraper to pry off the cover very easily. I saw three screws, the most rearward of which was loose enough that you could wiggle it and make noise. I tightened it, but it almost felt stripped. I left the cover off to drive and listen for it. I appreciate your help!
Ron is right..that screw is not part of the speaker itself, but if that screw was that loose, I would think it WOULD cause some rattling to the housing it's in from the speaker action. If you can't tighten it cause it's stripped, then put a slightly bigger diameter self-tapping style screw in it's place, see what happens.I have a Tradesman with the lowest level system. This is a picture from someone else's upgraded system, but I circled the screw that was loose in my truck.View attachment 50570
Any idea what to do if the screw is stripped? It felt like it was screwing into a plastic piece. I don't think the screw would be stripped as much as the piece it's going in to.Those are the kicker speakers that they have been talking about swapping in. The screw circled has nothing to do with the speaker, but glad you found it. Hopefully that is the gremlin that has been rattling.
Thank you for the advice!Ron is right..that screw is not part of the speaker itself, but if that screw was that loose, I would think it WOULD cause some rattling to the housing it's in from the speaker action. If you can't tighten it cause it's stripped, then put a slightly bigger diameter self-tapping style screw in it's place, see what happens.
Or you can put a toothpick in the hole before you put the screw in, that will give it some bite and tighten right up. Just break the toothpick off once the screw is started.Ron is right..that screw is not part of the speaker itself, but if that screw was that loose, I would think it WOULD cause some rattling to the housing it's in from the speaker action. If you can't tighten it cause it's stripped, then put a slightly bigger diameter self-tapping style screw in it's place, see what happens.
