How much to repaint Ram?
Discraftpro
As most of you know, trucks are in low supply. I was looking for a Ram in the smoked out (Granite?) Night edition with four wheel drive. Not to be found in my neck of the woods with the split tail gate. I settled on a white night edition limited because it was the closest that I could get. I will be looking at possibly painting the truck in the next year or so. I was wondering if anyone had repainted their Rams and could just share ballpark numbers. Once I get a quote here, I will share that as well.
Shane
GonzoNerd
For a total color change from a reputable place I would think $2500 to $3000, but that might be on the low range these days.
MannymanX
5thGenRams Supporter
AzZona
I'd say more like $5000-7000 if you want it done right.
I'd go with a good quality wrap anyway... Satin finish granite color... It'll look amazing..
SD Rebel
San Diego, CA
A full repaint? Done right, you are looking at at least $5,000 for a quality OEM style paint job, which includes removing trim and seals. Likely not including door jams or engine bay, that would be a lot more. It will also likely hurt resale value that you changed the color with a new paint job.
You may want to consider a quality wrap instead. When done correctly, can look like a new paint job and protects the real paint under it for when you want to trade or resell it. Wrap of that level is around $2,000 and higher depending on the shop.
zralph1
Have you considered wrapping it? It’s not cheap, but I’d imagine it’d be roughly half of a good paint job, and should last quite a long time if you get it done by a reputable shop. And also the colour/finish options are pretty much endless.
mikeru82
The Palouse
You won't qualify for the stormtrooper (aka panda) club if you change the color. :ROFLMAO:
Biga
Cincinnati
For full repaint at least 5-7K. I personally would not do it, factory paint is almost always better then a repaint.
scottmoyer
Just for comparison, I had a 2017 Mustang GT that had a paint defect. Ford authorized a repaint of the car and the dealership that did the work, took the car completely apart. They did do the door jambs also. All windows were removed form the car, all trim and the bumper covers. The cost to do this was almost $8000. You might get a Maaco paint job for $2500, but expect to pay a lot more if you want a quality job.
KRField
Tri-Cities, TN
Just FYI in I was quoted 6,800-8000 to repaint a 4th Gen and that was factory color, that was not jams or engine bay.
Fatherof3
Ontario Canada
Have you considered just trading it in for the color you want in a year or two ? You could order exactly what you want and it might end up being cheaper than a quality repaint . Just a thought .
