AtlasRam1500
- Oct 23, 2018
will do i pick it up in the tomorrowWould love to see pictures after install.
Yeah that would be frustrating however ORP/gearing/tires will do that.I average 13-14 in town, 15-19 on the highway. I have 3.92 and the off-road package, I think the more aggressive tires might be why I get such terrible mileage. I don't drive very hard, but I always get terrible mileage. My friend has the same truck as me just without the off road package and gets 3-4mpg better than me on the highway, it's frustrating!
Did thry try and say anything about impacting warranty work? I cannot imagine it impacting it other than, premature compressor failure for some BS reason of supppsed bag inflation difference which there shouldnt be, or foreign contaminants entering system from disconnecting. Both BS.2019 Limited with Air suspension Nitto Ridge grappler 285/55/22 with Revel link front and daystar space. Replaced Upper control arms with the Mopar 2In level kit uca drives very close to oem ride smooth just a slightly more bounce but not bad picture is taken in normal mode
I let the dealership install it warranty is still good not an issue. The airbag inflation has not change from stock to level what raise it was a space on top of the airbag strut. I had a 2014 ram that had airbag and did the same adding the space with links. the dealership installed and about 2 year the passenger side airbag failed the dealership replaced both front as a set for me. never had any problems with the dealership.Did thry try and say anything about impacting warranty work? I cannot imagine it impacting it other than, premature compressor failure for some BS reason of supppsed bag inflation difference which there shouldnt be, or foreign contaminants entering system from disconnecting. Both BS.
Think you could fit mud flaps with those tires? I presume turning left or right there will be too little room when you turn the tiresI let the dealership install it warranty is still good not an issue. The airbag inflation has not change from stock to level what raise it was a space on top of the airbag strut. I had a 2014 ram that had airbag and did the same adding the space with links. the dealership installed and about 2 year the passenger side airbag failed the dealership replaced both front as a set for me. never had any problems with the dealership.
When you disconnect the system at the entry level. this is when the bag is fully decompress, so there nothing that will enter the system because of a check value. never had a problem plus if i need to service my tank i have nitrogen available at my work
What I have (3.21/33). Love mine.I have 3.92 I dive it like I stole it lots of highway driving average mpg 16.5 my next truck will be 3.21 with 33 gallon tank
Is that a body color grill? Is that a new option or did you have it painted?
I disagree. Driving characteristics play far more of an impact. Gear ratio does not play a 1:1 effect on fuel mileage like it does with cruise RPM I believe, so no where near 20% decrease on 17 combined MPG due to gearing.Driving styles vary and have an impact but its clear that 3.92 have a significant impact on fuel mileage over 3.21's, its far more than 1-2 mpg. You are dealing with 20% more gear/higher rpm
3.21 to 3.92 is a 19-20% increase in rear gear, cruise speed at 70 is 1500 rpm vs 2000 is a 25% increase in engine rpm (more rpm = more fuel)I disagree. Driving characteristics play far more of an impact. Gear ratio does not play a 1:1 effect on fuel mileage like it does with cruise RPM I believe, so no where near 20% decrease on 17 combined MPG due to gearing.
