Horn sounds with passive entry/exit
Update:
Called the dealer and they told me how to disable the horn.
Open the drivers door and make sure the dome light is on then push the ignition button to run but dont start, then push the ignition button to off then push the button on the blue led light three times, the horn should honk letting you know its been disabled.
This worked for mine and now no annoying honk when I exit the truck.
I will also add, the SVR is not the alarm thats strickly a gps tracker, the truck has a seperate alarm system.
Update:
Thank you for that update! I was losing my mind trying to figure out how to turn off the horn on lock/unlock because the settings in the Uconnect system weren't taking hold.
Update:
That worked! Thanks!
