I love the color of your truck.It's not as bad as one might expect. Just go slow and I'd recommend using fairly rigid plastic pry tools that have a good curved "pry" end. I used some painters tape to protect the hood.
I pried free the outside corners first and then as far back toward the center of the hood as I could comfortably reach using the pry tools. Once it was free on both ends, I pretty much just lifted the bezel the rest of the way to release the remaining clips toward the center of the hood.
You just have to lift until the clips fail or break free. You can see that some of the clips shattered or broke and some were still intact in the hood.
If you need for me to elaborate on how to install the replacement bezel, I suggest you put down the pry tools and walk away from your vehicle.
No...I think he did mean the badge and not the entire plastic shroud.I think tdokmo was referring to removing the entire bezel, not just the emblems on the bezel. I too am looking to do the same thing but it seems this clips into the hood. View attachment 28503View attachment 28504
Yes, they are removable.Curious does anyone know if the hood vents are removable as well?
Thank you sir!Yes, they are removable.
Thank you. This is exactly what I needed to see. I was worried about denting the hood with a pry tool. I thought maybe going in under the hood and clipping off the ends of the clips but someone else posted they are not all exposed.It's not as bad as one might expect. Just go slow and I'd recommend using fairly rigid plastic pry tools that have a good curved "pry" end. I used some painters tape to protect the hood.
