While driving my 2021 Ram 1500/Hemi 5.7L, how do I know on when my engine got into 4 cylinder driving mode? Eco light? Thanks!
some level 1 or A equipment group do not have this option. you have to set it manually every time you put the truck into driveYes, the Eco light on the 5th gens will come on in MDS mode. If you haven't already, you can turn on that light in the Uconnect screen options.
While you are at it, you should also turn on your "Current Gear" option in the gauge menu settings, which is off by default. This is a nice little feature that shows you what gear your truck is in currently.
eco shows only when in 4banger no way to adjustGotcha, current gear or Eco?
gear only when manually set
gear selector on the steering wheel using + and -Wow, that's interesting, how do you turn the current gear indicator on with that system? You have to fiddle through the menus as well?
I think you might be confusing this a little. They all have the option to turn the ECO light on or off, which has no effect on MDS operation. It just enables/disables the indicator. To disable MDS you have to use the gear limit switches all Hemi equipped 5th gens.some level 1 or A equipment group do not have this option. you have to set it manually every time you put the truck into drive
