Hemi question
Zemlyak
While driving my 2021 Ram 1500/Hemi 5.7L, how do I know on when my engine got into 4 cylinder driving mode? Eco light? Thanks!
Yes, the Eco light on the 5th gens will come on in MDS mode. If you haven't already, you can turn on that light in the Uconnect screen options.
While you are at it, you should also turn on your "Current Gear" option in the gauge menu settings, which is off by default. This is a nice little feature that shows you what gear your truck is in currently.
some level 1 or A equipment group do not have this option. you have to set it manually every time you put the truck into drive
eco shows only when in 4banger no way to adjust
gear only when manually set
Wow, that's interesting, how do you turn the current gear indicator on with that system? You have to fiddle through the menus as well?
gear selector on the steering wheel using + and -
Isn't that the gear limit?
The current gear is another indicator that would be to the left of that one on the gauge that shows your current gear. Or did they combine that version?
I think you might be confusing this a little. They all have the option to turn the ECO light on or off, which has no effect on MDS operation. It just enables/disables the indicator. To disable MDS you have to use the gear limit switches all Hemi equipped 5th gens.
Edit: I guess I can't speak to the small gauge cluster display or small uconnect screens, since I haven't used them.
