Chanyote66
- Apr 29, 2020
Here is some insight on the problem from an engineering standpoint,
The aluminum heads expand and contract at almost exactly double the thermal expansion coefficient of iron.
If they overbuilt the manifolds, which if you have battled getting one out, you would know it is heavy and overbuilt, Then the flange area is too rigid to flex to the expansion and contraction of the head. Many other cars and trucks that still use Iron manifolds with aluminum heads, but if their manifolds are thinner and more flexible, they can handle the expansion better.
The big reason that the headers do not have this issue is that it is tubes welded to a flat plate, the flat plate can flex and expand/contract better with the engine than what a large 3 dimensional monolithic iron chunk can.
some reference points:
Thermal expansion (fractional expansion per degree C x10^-6)
Aluminum 24
Iron 12
Steel 13
In regards to the warranty work, How much do you value your time? If you have to spend a few hours a year driving to, waiting at, and returning from the dealership, that a lot of wasted time, Surely more than $600 of your time wasted "fixing an issue" the exact same way it broke last time. Just go get headers and install them, if you tow, get the little bit of gains from the shorty's and stop driving to the dealership all the Damn time!
Aluminum 24
Iron 12
Steel 13
