Ram uses the same interior design assembly philosophy across most of their models, so I think this will help you, but this is a rough instruction since I've not removed one from a conventional cab model.I am looking to run a wire from my third brake light inside the cab down through the rear regular cab pillar. Could somebody give me a step by step on removing the interior trim panels? I’m View attachment 96803View attachment 96803
Trying not to break any of the parts when removing. No airbag under the triangular tab, correct?
View attachment 96804View attachment 96804
thanks!
