Help needed on 2020 -2500 reg cab
Dave65
I am looking to run a wire from my third brake light inside the cab down through the rear regular cab pillar. Could somebody give me a step by step on removing the interior trim panels? I’m 213F6EAD-02B0-447F-97F8-D284D9E04D17.jpeg213F6EAD-02B0-447F-97F8-D284D9E04D17.jpeg
Trying not to break any of the parts when removing. No airbag under the triangular tab, correct?
thanks!
I am looking to run a wire from my third brake light inside the cab down through the rear regular cab pillar. Could somebody give me a step by step on removing the interior trim panels? I’m View attachment 96803View attachment 96803
View attachment 96804View attachment 96804
thanks!
Ram uses the same interior design assembly philosophy across most of their models, so I think this will help you, but this is a rough instruction since I've not removed one from a conventional cab model.
Locate the bottom edge of the Upper Trim Panel (the one you want to remove). If the lower edge of the upper panel fits over the top of the lower panel, you should not need to remove the lower panel.
Locate the close-out cover that says, "SRS Airbag" and carefully using a small screw driver, pry the cover away from the lower edge. There will be a torx screw behind it that must be removed.
At this point the upper panel can be pulled away from the body. You will need to feed the seat belt adjuster through the slot in the panel. There is a cover over the seat belt adjustment head that can be removed using a trim stick or other tool.
If you cannot fish a wire down the inside of the lower panel, you'll need to remove the rear panel behind the seat.
Best regards and good luck,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 052263 miles.
