Help identify picture
Cease11
I think my steering rack might be leaking? Is this the steering rack?
Scram1500
It looks like motor oil, the filter is right above that area
Cease11
The reason why I was looking down there is because I’ve been getting a grinding noise that is very noticeable coming thru the steering wheel. It’s like a grinding noise. Any thoughts?
Cease11
That sounds like a rattle or vibration to me; I don't hear grinding
It’s a weird noise if I put my ear to the steering wheel it sounds really loud.y tires are almost out. Maybe that can be the cause too.
11B4X4
Northern Virginia
Sounds like the same noise that I have/had. Try applying some light pressure on the backside lip of the steering wheel front plate (the piece with the ram logo) By pressure i mean pulling it towards you. Mine would make that noise at certain speeds and RPMS. I was able to take a rubber ear plug and wedge it between the plate i was describing and the steering column...problem solved...If you need some more clarification I can post a pic once I get home
Alex2014
Hi, please post a pic. Thanks!
Cease11
Thanks for the advise! I will definitely try that out. Same thing it only does it at certain rpms. Can you please post a pic to see exactly where you wedged it in.
