My new 2025 Dodge BigHorn Crew Cab with 6 Cylinder Twin Turbo doesn't play my USB Dongle that is loaded with
GOSPEL Music. I leave the USB Plugged in 24 Hours a day. When I start the truck, the LED is on the USB Flash
Drive, so It is seen by the Truck on the USB Port USB1. I go to Music and Select USB1 and I hear a CLICK. It's like
the Audio is going to play the USB's Music. I scroll down my DASH and the MUSIC is ALWAYS MUTED. If I un-Mute
it, it appears as if it is going to play, but instead it now says NO DEVICE DETECTED. But, the USB LED is still
"ON" and Further Clicking on USB1 does nothing. The ONLY way to listen to my GOSPEL Songs is to REMOVE the
FLASH DRIVE, then Plug it in, and REPEAT the Above Process. Now, when I enable the MUTED MUSIC it starts
Playing, and continues until I power off the TRUCK.
Obviously, some ENGINEER DID NOT TEST the Functionality of the USB PORTS, and Let a BUG slip through the system.
Why isn't AM, FM, and SIRUS, ALSO MUTED when I select therm? But, no it's just the MEDIA Player. Who Designed this
CONJURED UP SYSTEM, and DID NOT TEST it? It should take less than 2 Minutes to see the ISSUE. Go try it!
Is there a way to use AlphaODB and correct the ISSUE? How Many Years of Unplugging and Plugging my USB Flash Drive
is it going to be before I can properly listen to Gospel Music.
Everything else on the 2025 is GREAT. DON"T drive one unless you take your Checkbook.
Larry Kraemer
Chaffee, MO USA.
Larry Kraemer
Chaffee, MO USA.
