Grille insert swap??
CMil527
Old Bridge, NJ
Anyone know for sure if the grille inserts are a simple swap or does it require to swap out the full grille and surround?? TIA
CMil527
Old Bridge, NJ
Searched with no luck but thanks and no that search link is/was not my question. My grille is all black.. looking to see if anyone has successfully swapped out the inner grilles without replacing the full grille. Ive personally done it on previous gen rams but never seen it done here.
NorthStar
Texas
See the link below as this contains the information you may be seeking (the short answer appears to be they cannot be replaced, only "augmented"):
CMil527
Old Bridge, NJ
Damn, nothing is ever easy... thank you sir!
