CMil527
Anyone know for sure if the grille inserts are a simple swap or does it require to swap out the full grille and surround?? TIA
Searched with no luck but thanks and no that search link is/was not my question. My grille is all black.. looking to see if anyone has successfully swapped out the inner grilles without replacing the full grille. Ive personally done it on previous gen rams but never seen it done here.
Damn, nothing is ever easy... thank you sir!See the link below as this contains the information you may be seeking (the short answer appears to be they cannot be replaced, only "augmented"):
Has anyone removed these grill inserts?
Hi all, Just wondering if anyone has removed these grill inserts and how? It looks like they separate from the main grill. I’d like to remove them to have them vinyl wrapped. Thank you!5thgenrams.com
