Granite crystal metallic thread
I hate how they have assed it with the badging. At least paint all the badges “red” and not just the front one.
Guess they said screw the rears lol I would like to see the ram head in the back in red. The others badges you can just delete :)
Plasti-dip would be a cheap option.
Looks great! I’m trying to be cost effective about getting rid of the chrome… I don’t feel like spending $230 to replace the door handles… wish that chrome in the door handles could just pop out and replaced with painted to match parts
2019 Ram 1500 Limited Granite Crystal 4x4 with Off-Road Group and air ride
20% Cermanic Tint
USA Flag Decal on rear 5th Window
Xpel Door Edge and door handle Protection
@RamSportDT
Do you have a close of under cab where the gap is closed up? Near the rocker? And maybe from the mounting side too?
I have Westin R7 and just picked a set of these up today for 600cdn (460usd) as I really liked them on a coworkers 2022 Rebel. I like the design and the fact the match the bumper steps.
Because my Westin R7 steps had a gap between cab and step I installed running board lights that are stuck on the rocker panel infront of the pinch weld. I want to see if these steps will block my lights or not. I'll fund out later when install but I'm curious to get an idea. Weather is bad right now so not sure when I will install them, have to wait for a warmer winter day without snow
If they do block my running board lights then I he other ideas in mind to fix that. But again weather will need to be warmer before I get into that.
Can I ask what wires you tapped into for running board lights?
Here’s my 22. Just shy of 800 miles. Going back to the dealer on Friday for some issues. Air vent, tpms issue and airbags? Otherwise I friggen love this thing.
What issue are you having with the airbags?
There’s no warning lights on the dash, but the uconnect app health check is telling me they aren’t functioning. I think it’s all uconnect related. When I start the truck it tells me my front two tires are at 6 psi. But when I check through the dash cluster it shows fine. Same with the airbags
The uconnect display shows an error when I turn it on. But then goes away. It’s not throwing a code for anything other than the issue with the air vent. Which apparently is an issue with all the 5th gens
Love the lift/wheel/tire combo. IMO perfect setup. How’s the ride quality?
Actually pretty solid. It felt maybe a bit too firm when I first put the tires on but after about 500 miles it started to feel a lot better to me. It’s obviously not stock, but I’m very happy that it still rides as smooth as it does.
