Getting my TRX wheels tomorrow morning. I currently have a 3/2 Moto level lift. Will I need wheel spacers?
Filmnews
Will I need to put wheel spacers on to clear the front suspension? I have seen where it rubs on trucks with no level/lift. I have a set of wheel spacers coming in the mail, but I don't really want to use them.
Derek Dredger
United Arab Emirates
The information you need to find here is; what is the wheel offset of your current setup (that I assume does not touch any suspension components, mainly your UCAs) and what is the offset of the TRX wheels? Based on this there are websites you can use to calculate if any touching/issues will arise.
RebelWraith
Polymath
Montclair, Va.
The wheel doesn't rub, but the tire does if you use the TRX tires. If you go with a thinner tire then you won't make contact with the UCA.
DentalDart
You need wheel spacers. I run 1.5in wheel spacers. I have air suspension and 2.5in level using the airlinksgc level links and the 2.5in daystar spacers. 20220109_165910.jpg
