Looks good , i bought the 275 65 20sLT 275/60r20
First miles are slippery, because i did the level and tires at the same time i can't tell what cause the biggest impack. Ride got bit more stiffer than stock but i am use to it now and not bad. The look is great
Got about 4k miles on them.
Can you report any mpg drop? This would've helped going in the tires sub forum. Am interested in the 18" ATX's.LT 275/60r20
wanted to go that size but I was super limited with height clearance at home and didn't want to take a chance. Have since gained some height so next set of tires will go up that sizeLooks good , i bought the 275 65 20s
I noticed less 1 mpg from stock tires - I have not recalibrated the speedometer - I only keep an eye on the numbers like 2 days cause no reason to keep getting depress over the city numbers which were worse early on than my current numbersCan you report any mpg drop? This would've helped going in the tires sub forum. Am interested in the 18" ATX's.
I ordered the 275 65 20s and i have a two inch level kit is there enough room for the taller tires on your truck?I noticed less 1 mpg from stock tires - I have not recalibrated the speedometer - I only keep an eye on the numbers like 2 days cause no reason to keep getting depress over the city numbers which were worse early on than my current numbers
current set up LT275/60R20, front level, both air dams delete, 1.5 wheel spacers all around, interesting 1st time I think about the spacers and mpg - so not sure how helpful my numbers can be to others
current mpg 12-14 city with a lot of short trips and stop lights, 18-20 highway
I got room to clear the size you ordered but I have a 2.5 level (1"off road group + 1.5 level struts)I ordered the 275 65 20s and i have a two inch level kit is there enough room for the taller tires on your truck?
Ok thanks ! I get the new tires installed tommorow , did you have to adjust your tpms settings ?I got room to clear the size you ordered but I have a 2.5 level (1"off road group + 1.5 level struts)
There is a member here that is running 285/65r20 with a very slight rub and just the ORG which is 1" higher at front - see post #5,9,14 for his feedback
So I feel you should be fine with the 2" you have -
34 inch tires with stock suspension?
Hello everyone, I’m kinda new to posting to the forum though I’ve been a lurker for quite a while. I have a 2021 1500 DT with the off road group, 3.92 gears, and a 3.0 ecodiesel. The truck is a crew cab 6’4” box. The Factory 20 inch rims are wrapped in falken wildpeak ATs that are size 275/55r20...5thgenrams.com
I didn'tOk thanks ! I get the new tires installed tommorow , did you have to adjust your tpms settings ?
I agree with frisby5 - 1-2 miles lostHow are the tires? MPG loss?
