General Grabbers ATX
frisby5
Anyone running General Grabber ATX on their Ram 1500 ? I ordered some just wondering how they run .
jl13
boyle heights, CA
LT 275/60r20
First miles are slippery, because i did the level and tires at the same time i can't tell what cause the biggest impack. Ride got bit more stiffer than stock but i am use to it now and not bad. The look is great
Got about 4k miles on them.
frisby5
LT 275/60r20
Looks good , i bought the 275 65 20s
Bt10
MI
LT 275/60r20
Can you report any mpg drop? This would've helped going in the tires sub forum. Am interested in the 18" ATX's.
jl13
boyle heights, CA
I noticed less 1 mpg from stock tires - I have not recalibrated the speedometer - I only keep an eye on the numbers like 2 days cause no reason to keep getting depress over the city numbers 😅 which were worse early on than my current numbers
current set up LT275/60R20, front level, both air dams delete, 1.5 wheel spacers all around, interesting 1st time I think about the spacers and mpg - so not sure how helpful my numbers can be to others
current mpg 12-14 city with a lot of short trips and stop lights, 18-20 highway
frisby5
I ordered the 275 65 20s and i have a two inch level kit is there enough room for the taller tires on your truck?
jl13
boyle heights, CA
I got room to clear the size you ordered but I have a 2.5 level (1"off road group + 1.5 level struts)
There is a member here that is running 285/65r20 with a very slight rub and just the ORG which is 1" higher at front - see post #5,9,14 for his feedback
So I feel you should be fine with the 2" you have -
frisby5
Ok thanks ! I get the new tires installed tommorow , did you have to adjust your tpms settings ?
frisby5
I really like the tires . Havnt really paid attention to mpg probably lost a mile or two . But my truck is not a daily driver only a weekend warrior lol
jl13
boyle heights, CA
How are the tires? MPG loss?
I agree with frisby5 - 1-2 miles lost
I'll reference my highway - average is 17, best I have seen is almost 18 - best I saw in stock was close to 20
I did do the tires and leveling kit at the same time
PaGregSS
I had them on my 2019 Bighorn. I was very pleased with them. I got 50K miles out of them, rotating them religiously. I had the D load range for towing. They handle all conditions well. I'd recommend them. When they needed replaced, I decided to try some Nitto Recon Grapplers in an XL to try to get some fuel mileage back. I didn't really like the Nittos. I ended up trading the truck in with them on with only a few thousand miles on them.
