Same here. Just installed last weekend and works perfect. I bought the snap in hose nipple kit. The one with the built in tube looked nice but much too close to the sway bar for my comfort. Probably wouldn’t be a problem but why take the chance.That’s why I went with the SX version.
Jack up the truck from the front cross member until both wheels are equally off the ground. That would be the full travel of the bar
dont be scared #YOLOI did just that. It, in fact, gets close to the long nipple version but it does not make contact. I’ll attach a picture.
With this being said, I may swap next oil change with the S version. I appreciate your valuable input.
what skid plate is that ?Standard, long nipple no problem
Must be the extra lift from the ORPNope, mine was literally touching with no way to install without risking cross threading. So I now have a nice paperweight.
It's possible. I also have the Bilstein 5100's at #2 (2nd lowest) setting.. but you'd think the Rebel guys or anyone with a leveling puck would have the same issue, right?Must be the extra lift from the ORP
