Front Valance Removal?
CLAZ2020
Has anyone removed there front air valance? Or "front valance delete" as some call it? Is it relatively easy to do? I don't like the look of that huge piece of plastic, I understand it is for aerodynamics. Thanks.
Billet1500 4x4
California
Easy to do, If you have the active air dam behind it you will also have to remove it as well, which also comes off very easy. not sure if the truck will give an error code once the active air dam has been unplugged.
TheTsieck
Philadelphia
Did you ever remove it? Notice any issues?
FailGrenade
Southern California
Removed mine. Not hard at all. It's a bunch of 10mm nuts, I think 13mm and plastic push pins. No check engine light but may be a background code. But I love my look
BostonBLS
TheTsieck
Philadelphia
same for me. I just lifted my truck 3.5 inches and that piece doesn't allow me to get the look I want. ordered a bull bar from westin so when I install that I might just pull it off
FailGrenade
Southern California
Im putting a 2in level kit from motofab once it arrives and ill see the look after to see if it stays off. the active dam is though for sure
Mark derix
