Front tow hook bolt issue
Oilslick
N.E. Pennsylvania
I purchased a bull bar for my 2021 1500 BTS edition and the instructions require that the front tow hook bolts be removed. There are two bolts per side. One bolt on each side removes with no issues. However, the rear bolt holding the tow hook unscrews but doesn't drop from the frame. This applies for both the driver and passenger side of the vehicle. Anybody have any idea why the bolt can't be removed?
See pic for reference.
realralfy
It has a retention washer on it, that prevents it from simply falling out after you have loosened all the threads...loosen it all you can, and then put a good wrench at the top of the bolt body under the head of the bolt and hammer it out....It will take a few good licks to get it out, but you will feel it coming with every whack...
leedial
I took my hooks off to paint them and had similar issue. If I recall correctly, I was able to completely remove by keeping downward pressure while unscrewing at the same time.
millerbjm
St. Paul, MN
There is a retainer clip that holds that bolt up - you have to put a wrench over the bolt head and tap with a hammer until it comes out and then take that retainer off. Serves no purpose other than keeping it from falling out I think so no need to replace. You'll also have to Jimmy it gently around d the active air dam.
arod412
NJ
I used a pry bar…after unscrewing it and it came half way down.
Just light put pressure down on it, then it popped that retention clip.
2016 Dodge Charger scat pack and my wife 2021 Jeep Wrangler Unlimited Sahara
arod412
NJ
Thanks guys! I'll give it a try.
If that doesn't work, get a set of plyers. Then clip it at the neck of the bolt, right under the washer/bolt. Then lightly hammer down on it, and it will come out that way too. It does take to much hammering to get it off.
2016 Dodge Charger scat pack and my wife 2021 Jeep Wrangler Unlimited Sahara (2.5" rc lift with 35" duratracs)
mikeru82
The Palouse
This worked for me as well. No hammering needed to remove them on my truck.
