wallyuwl
- Apr 7, 2020
What size is that?Yes, look for something that looks like this
I would check the torque or the mount bolts they put in. You can rent a torque wrench for free or buy a cheap one from HF. If they are at least at 80ftlbs try going to 85. If that doesn't fix the clunk, it must be something else loose.Anyone have this solved yet. I've had the mounts changed out as per the TSB for the 2019's but it hasn't fixed my issue.
My 2020 ram 2500 doing the same thing. Took it to the dealer. Charged my $267.00 to diagnose it. Said upper balljoins$1043, shocks $780, and steering shock $450 needs to be replaced. (None of it covered by warranty) I changed balloons myself. Needless to say, the ones I pulled were fine and didn’t help at all. They know it’s a common problem, why not fix it on recall or say what the problem is. Not happy at all.I figure the tsb will cover 2020 pretty soon so I'll wait for that. In the mean time ill tighten the driver side a pillar body mount and see if that helps.
