2020SilverMidnight
- Feb 9, 2020
yea I get the angles of the pics show different. Can you measure top of the tire to the fender well straight in the middle? Maybe that would help.
What’s the complaints with the maxtrac 2/4 drop? I just ordered the kit and rear helper bags.
Can’t speak for my 5G, but I have a 2/4 maxtrac on my 2014 RC 4x4. Rides on bump stops, front struts are pretty riged, maxtrac rear shock completely dead at 5k miles on kit, and will not align to spec if lowered to the lowest setting on strut. I’m on the middle height setting. Added Firestone helper bags until I get it sorted, helped a LOT.What’s the complaints with the maxtrac 2/4 drop? I just ordered the kit and rear helper bags.
Well I went ahead and installed the kit along with the airlift helper bags. I did not try to lower the front to the lowest setting(3” lower than stock) but did go with the middle position(2” lower than stock). Got the alignment done today and the caster and chamber are close but barely out of spec, less than 0.5 degrees, but were able to get them to match side to side. I followed the instructions and trimmed the bump stops and no issues there so far. No issues with the rear end not being centered using their drop bracket and no shakes, shimmy, or other vibration issues up to 85mph which is as fast as I got it.Can’t speak for my 5G, but I have a 2/4 maxtrac on my 2014 RC 4x4. Rides on bump stops, front struts are pretty riged, maxtrac rear shock completely dead at 5k miles on kit, and will not align to spec if lowered to the lowest setting on strut. I’m on the middle height setting. Added Firestone helper bags until I get it sorted, helped a LOT.
Overall, just not impressed & will not install on my ‘19 5g.
Yes it is.Is yours 4x4?
Yes it is.
The front is easy it's just a strut with the spring perch lowered 2". The rear isn't hard to drop just 4" drop springs and shocks. You will need a few other components to make sure the rear is centered front to back and side to side. The hard part is designing something to prevent you from bottoming out. The only solution I've found involves cutting and that's where most folks get spooked.I don't really understand why a 2"/4" drop kit is so hard to engineer and manufacture. There has to be something to it because there is only 1 kit on the market right now and it's total ****. So, I'll just keep waiting.....
*Maxtrac 0-3" drop struts (set at 2") in front
*IHC 4/6 drop kit (rear components only) with the cut kit relocation bracket.
My bad, that was misleading. The IHC 3/5 and 4/6 drop kits come with 4" drop springs. You then have to cut the springs in order to get the 5 or 6" desired drop in the rear. By leaving the spring uncut it remains a 4" drop spring resulting in the aforementioned 2/4 drop.Wouldn't that make it a 2 / 6 drop though? Or am I being a moron, lol?
So I thought I would give a little update on my Maxtrac 2/4 drop kit. I did install helper bags when I installed the kit.
I already updated on the alignment deal, but to recap front caster and chamber are technically out of spec but they are less than 0.5 degrees from being working specs and they are even so no pulling.
After the springs settling in I did end up having some bottoming out in the rear. After looking at things and reading up on even the IHC kit it looked like I had 2 options: 1) to buy the IHC CUT control arm relocation brackets, 2) to cut the bump stop cups off. I decided on option 2 and it has provided me with close the factory upward suspension travel limit and have had no issues with bottoming out since. I do run the required 5psi of pressure in the helper bags and it is practically like factory ride. I even pulled a 7,500 lbs travel trailer with 25psi in the helper bags and no bottoming out issues and rode great, just like before being lowered. Over all I really like this kit and am happy with my purchase.
