Are floor mount anchors a factory thing or a dealer installed thing? My driver side anchor could be an inch farther separated. The matt does not sit flat and I constantly fighting with lumps and kicking it everywhere. How is everyone elses?
Yeah, definitely not good if it's bunching up near any pedal. You don't need to take it back to the dealership you bought it from. Any CDJR dealership can do warranty work on your Ram truck.Dealer i bought it from is over an hour away and not convenient to visit often. I will probably take it to a local dealer for an oil change and such and mention it see what they say. I have to fix it everytime I get in as it can bunch near the accelerator.
Here is my drive side mat. It has a pretty good hump in it and tends to get twisted in lost of directions. If I pull it out the stud is like an inch out of alignment. The passenger side fits much better. Does anyone elses mats fit like this?
Did that leave a hole in the carpet?Mine was like that too, so I pulled the rug back and relocated the pin. problem solved. Guess they were sleeping at the factory that day. Remember if you go to other floor mats like WeatherTech, you may be moving the pin again.
yes a slight hole so i cut a section of carpet from under the seat where it isn't seen and made my own plug and stuck it in the hole and put gorilla tape over the bottom of the plug to hold it in place.Did that leave a hole in the carpet?
