Filling up
Glad you hear got it fixed.
I was concerned that mine was a bad vent too and wanted the tank replaced under warranty if that was the cause.
Mine turned out to just be the filler neck.
Been having speaking that was getting louder. Dealer dropped tank again and found the mechanics wrench he had left on top the tank.
Turns out is was a combination of the neck and tank for me.
Replacing the filler neck with a new design solved the issue where the nozzle would shut off after a few seconds unless I slowly started to fill then worked up to full flow.
Replacing the tank (rollover vent valve) solved the issue where the nozzle would shut off a few gallons before the tank was full.
It took several visits but now I can fill up at any pump without issue.
