BendPharmD
- Sep 16, 2022
good to knowBak flip is you wanna a tri fold or Lomax is pretty cheap but doesn’t fold up to the back window like the Bak flip. Retrax if you want a retractable one.
Edit: Get a pair of Right on brackets since you have the multi tailgate
5th Gen RAM Truck Bed Replacement Brackets - Install A Tonneau Cover
Replace Stock Truck Bed Brackets To Allow A Tonneau Cover To Be Installed. USA Made Steel Right Angle Bracket. 5th Gen RAM Truck Bed Replacement Brackets.rightonbracket.com
Want a trifold.i'm planning to put the truxedo pro x15 on my truck here after the holidays are past. i'm in the same boat with the ram boxes and multi-function tailgate. check out their website -- the options account for all those variants.
there are also soft trifold covers and hard trifold coversWant a trifold.
This is incorrect information. OP does not have brackets, and thus doesn't need or can even use the right on brackets.Bak flip is you wanna a tri fold or Lomax is pretty cheap but doesn’t fold up to the back window like the Bak flip. Retrax if you want a retractable one.
Don't leave out climbing on top to clean off the snow or the 1600 lb load on top plus the tie downs or the racks you can add, plus interior compartments if you choose. Not all that of a hassle to take off, particularly if you have the center bracket marked on the rails. Parts are not that heavy as compared to taking off a Bak Flip Mx4 (not often necessary if you don't mind the window blocked) by yourself. Cost is a factor and what you plan on carrying and how often.It's spendy, but I prefer my Diamondback for security, weather-proof, and lifetime warranty.
All have + and -, need to figure your use and $$$.
