M3forged
- Mar 16, 2024
I'm pretty uneducated when it comes to wiring but I'm learning. Here's my question with some background first.
My trucks f26 fuse has to be pulled to completely disable stability control functions. A bypass switch works. I tried to wire that setup through my auxbeam instead and when I put the negative into the switch 1 negative terminal it immediately sparked and melted the wire. The positive was not hooked up yet. So I stopped there.
The wiring was spade connectors to the f26 fuse slot then there's the inline fuse (40amp) the positive wire and neg wire from that would normally go to the rocker switch. Slot 1 on the auxbeam has a 30 amp fuse. Any thoughts? Thank you.
