Etorque Battery Life
Kflinto
What happens if the etorque battery dies after a while? Is that a possibility and what will that do to the engine configuration?
Jordan2929
Syracuse NY
The battery is always being charged, whenever you're coasting its getting some juice. I wouldn't worry about it dying.
alacombe
I think @Kflinto means when it dies as if it needs to be replaced after a significant amount of time.
Jordan2929
Syracuse NY
Ahhh I see, someone said it’s covered under the Powertrain warranty so you should be good until then. But I also heard it’s around $1500 to replace.
alacombe
Seems like alot of this is hear say. I would like to see warranty document saying its covered under the powertrain and a document showing its $1500. both of these are hard to believe for me.
Jordan2929
Syracuse NY
Yep not positive, just what I read on here. You’d have to call your parts department on that one.
Kflinto
Ya exactly @alacombe batteries don’t last forever regardless how they charge. The cells will eventually die, etc. I would like to see this written somewhere for validation.
alacombe
Same here. I like seeing this on a written document/warranty by FCA not just hear say from a dealership or through other people.
Northeast16SS
Looks like I'll be trading my 2019 in before the power train warranty expires.
thcmas35
Tracking order
Tracking order
MN
My dad has a 07 Prius that is running strong. My 13 Volt doesn't show any degradation from when it was new. Battery design/chemistry plays an important role in longevity. I don't expect the battery to be a problem in these, but there is more risk considering it's a newer application. During my research, I found anecdotal evidence they were designed to last the life of the vehicle, which i'm not going to dispute. If there is an issue, they are relatively easy to access. I think an alternator would be more likely to fail over e-torque. But only time will tell.
Jus Cruisin
Metro Detroit - I miss FL
I guess I'll need to dig the warranty booklet out of the glovebox. I'm thinking about getting the extended warranty next year if, I'm still as happy with the truck as I am now. Meaning I am considering hanging on to it for a while. As far as coverage of the etorque battery..... If it is covered or not it won't be a determining factor of keeping it or not.
jamesfg
Phoenix
I'm going to get the lifetime warranty but I'll be asking about the etorque coverage before I hand over my credit card number.
Chris
Southern NH
Economics of scale will likely save you on cost by the time these are no longer covered by the warranty, as more and more vehicles are adding hybrid technology and requiring more batteries to be mass produced.
24 kWh Nissan Leaf (ours is only 0.4 kWh, 2% of the Leaf) batteries are $6k new, but will be getting refurbished and sold for $3k:
https://insideevs.com/nissan-introd...es-for-older-leaf-in-japan-from-new-4r-plant/
A start-up is aggressively pursuing manufacturing for $80 per kWh:
https://www.greentechmedia.com/arti...y-costs-below-80-per-kilowatt-hour#gs.zPO0rwc
Research shows the existing electric vehicle battery costs have dropped 60% over the last 10 years:
https://s3.amazonaws.com/files.technologyreview.com/p/pub/legacy/jan11_feature_electric_cars_p61.pdf
A government study showing the market for batteries and demand for mass production significantly increasing:
https://www.eia.gov/analysis/studies/electricity/batterystorage/pdf/battery_storage.pdf
The economies of scale have proven time and again that expensive technology gets much cheaper as it stagnates; LCD screens are a prime example, with costs being only 10% of what they were 15 years ago. It doesn't get much more stagnant then battery technology, and the demand is exploding as more devices make use of it.
The biggest risk is supply being bottlenecked by resources such as lithium and other rare earth minerals; the planet only has so much, and the more that is needed, the harder it is to find. Recycling will help to a large degree, since you can't just throw an old 18 cubic foot 1 ton battery in the trash and the only way to replace or dispose of it will be through a recycling center; however, that doesn't stop the other 90% of the small batteries from going right in the waste bin unless a significant refund is offered for them (e.g. a core charge for cell phone batteries when you recycle an old phone or swap batteries).
Personally, I am confident that my battery will be covered by some kind of warranty while it is still expensive, and will be relatively cheap to replace by the time the warranty expires; I'm expecting somewhere in the ball-park of the cost of two lead-acid 12-volt batteries.
PTK1412
The battery on my 2019 just went out. Cause the truck to randomly shut off when in low idle. Battery cost 2700 but is covered by Federal Emissions Warranty 8 Years/ 80,000 miles
script
Glad to hear it's covered under warranty. Not excited to hear of these dying after just 4 years. Is $2,700 including labor or is that the cost for just the battery?
Darksteel165
Massachusetts
The battery should cost $1500.
Not sure where the $2000 is coming from.
Assuming ram keeps them in stock and you can actually get one. I know most people wait several months to get a replacement even under warranty during that time the truck can't be driven.
