Jako
1. What Information: Pg 293 2019 Ram 1500 Owner's Manual1. What information?
2. Does any other manufacturer?
3. Why would you need a "break-in" brochure PRIOR to purchasing ANY vehicle?
ENGINE BREAK-IN RECOMMENDATIONS
A long break-in period is not required for the engine and
drivetrain (transmission and axle) in your vehicle.
Drive moderately during the first 300 miles (500 km). After
the initial 60 miles (100 km), speeds up to 50 or 55 mph (80
or 90 km/h) are desirable.
While cruising, brief full-throttle acceleration within the
limits of local traffic laws contributes to a good break-in.
Wide-open throttle acceleration in low gear can be detrimental
and should be avoided.
The engine oil installed in the engine at the factory is a
high-quality energy conserving type lubricant. Oil changes
should be consistent with anticipated climate conditions
under which vehicle operations will occur. For the recommended
viscosity and quality grades, refer to “Fluids And
Lubricants” in “Technical Specifications”.
2. Do other manufacturers: Yes, My 1985 Toyota Corolla had a break in period, 1994 Ford Explorer, manual pg 15., "2001 Dodge Ram Truck" manual pg. 39, 2006 Honda Accord pg 153, 1980 Kawasaki LTD 650 manual pg. 38, BMW MCs: 2003 BMW R1200RT, 2004 BMW K1200GT, 2016 BMW K1300S all had beak in periods.
3. Don't need a brochure, just "There is no "paper" that comes with the vehicle, e.g. (for example): a sticker or a pamphlet to inform you of the break in."
Break-in period is similar to "When do you do your first oil change". Opinions vary. I do my best to follow manufacture's recommendations and read the manual. Most vehicles are ordered to my specs and that gives me time prior to dealer delivery if I have access to the information.
