Electronic issues Radio, AC, and Front Power Windows
I went ahead a made the dealer appointment for Monday and they wont be able to look at it for 4-5 days.
Then tell the dealer you will drop it off in 4-5 days when they are ready for it. Why make an "appointment" when they aren't even going to look at it that same day.
I've tried that before. they don't give a dam.
Might be worth checking for loose or corroded grounds.IMG_6452.jpgIMG_4672.jpeg
I actually got it figured out.... hopefully! I read in another thread that someone found a bunch of fuses not pushed all the way in. While going through the fuse box, I figured out that the fuse taps for my dash cam were causing the issue. Once I removed them, everything was back to normal. Not sure exactly which one was doing it.
it has been good for 2 days now
That's good news, thanks for sharing the solution. So not a Ram problem after all, an after-market problem.
Yup. I wanted to make sure to post this in case someone else encounters the same issue. I know many people use these for dash cams. I have used this type of fuse tap on all of my trucks and never had one give me issues.
Ended up being a short in my driver side tail light when i disconnected the tail light everything worked have to order a new one. Looks like they are $500 to $700 for tail light assembly, with sensor🤦‍♂️
This is a godsend, I’m having the same issue and I also have a damaged tail light🙏
