Then tell the dealer you will drop it off in 4-5 days when they are ready for it. Why make an "appointment" when they aren't even going to look at it that same day.I went ahead a made the dealer appointment for Monday and they wont be able to look at it for 4-5 days.
.I actually got it figured out.... hopefully! I read in another thread that someone found a bunch of fuses not pushed all the way in. While going through the fuse box, I figured out that the fuse taps for my dash cam were causing the issue. Once I removed them, everything was back to normal. Not sure exactly which one was doing it.
it has been good for 2 days now
This is a godsend, I’m having the same issue and I also have a damaged tail lightEnded up being a short in my driver side tail light when i disconnected the tail light everything worked have to order a new one. Looks like they are $500 to $700 for tail light assembly, with sensor![]()
