Eaton TrueTrac Reviews?
MikeStaten
Thinking of putting this limited slip differential in a 2021 Ram 1500 4x4 Crew Cab with 3.21 axle. The truck has an open differential now. Is there any negative in adding the Eaton? Will I likely notice a big difference between the open diff and the Eaton? Primarily looking for better traction for rain or snow conditions. Will occasionally use the truck for towing a 5k pound camping trailer too. Also, anyone know of any good shops in NJ to do the install? Ballpark pricing on labor?
Thanks, Mike
jdefoe0424
Illinois
You'll notice a big difference in the winter in snow. I seriously miss it in my 2500, have to put it into 4x4 when I didn't have to with my 1500.
Sadly there's nothing aftermarket out for the new 2500s yet.
UnloosedChewtoy
5thGenRams Supporter
South Dakota
Welcome aboard!
Cannot help with the NJ locations/shops. Labor to install a LSD in an older Ram, including redoing the gears, was in the $800 range, if I recall correctly. Probably similar to the new ones, maybe a bit more now-a-days. But its been a while, I could be remembering wrong.
Do not forget the master install kit, and do not cheap out on that either. Do it right the first time. When you're spending that much money, trying to save less than a hundred bucks with a mini kit or a cheapo kit is not worth the potential disaster/redo it may lead to.
I believe Moe's sells a nice one (link below).
U
User_18352
Guest
I put a Detroit TrueTrac and 4.11 gears in a Jeep JK I owned about 10 years ago when I moved up to larger tires. I really liked the idea of an LSD being driven by worm / helical gears as opposed to crappy clutch packs which have a tendency to wear out real quick sometimes. The truetrac worked flawlessly in inclement weather / road conditions and offroad. It always seemed to kick in when I needed it, otherwise I didn't even notice it was there, very smooth under normal driving conditions.
IvoryHemi
I also had TruTrac’s in a Jeep. They were phenomenal in snow. I’d highly recommended them and will buy again myself when the time comes.
I figure once I hit 50k on my factory LSD the clutches will be toast and I’ll upgrade to a TrueTrac LSD then.
I don’t think you’ll notice much if any difference when towing, but definitely in lower traction situations like the rain/snow you mentioned.
BowDown
Frisco TX
I wouldn't count on that, my last ram with LSD lasted 277K miles and was still tight
MikeStaten
Thanks all. I’m going to start looking at shops to install. If anyone knows a good shop in NJ or eastern PA, please let me know. Thanks
Just installed one last month. Best money I ever spent. Labor was $600. Truetrac $540, bearings $175, Lubelocker gasket $25, gear oil $50
