Tinshield
- Nov 23, 2021
Never seen that app on mine
Mine disappeared after a factory reset and never showed back up haha.Never seen that app on mine![]()
I ordered a Backcountry a few weeks ago with E-Torque but now having second thoughts and thinking about changing the order to the standard Hemi without. After researching it more I’m just not sure E-Torque is for me.
I was under the understanding that Stop/Start could be permanently disabled by turning off but sounds like it needs to be turned off at each start up when driving….correct?
It would be great if it drastically improved fuel economy but seems like more of a gimmick than anything else and doesn’t add much plus concerns about future expensive repairs to costly replacement parts that otherwise wouldn’t be needed.
Sounds like others are conflicted as well. Decisions……Decisions![]()
Fuel economy might not even be top 5 for why I like the system, but mine is pretty good.It would be great if it drastically improved fuel economy but seems like more of a gimmick than anything else and doesn’t add much plus concerns about future expensive repairs to costly replacement parts that otherwise wouldn’t be needed.
We’re you coasting downhill for 33 miles?Fuel economy might not even be top 5 for why I like the system, but mine is pretty good.
I have the E-Torque and the transition from not running to moving again is seamless. The electric motor starts and you do not know it from the engine running and then transitions to the engine. The electric motor also make some of the shifts between gears much smoother. It is a very smart system. It also adds a bit of torque.I ordered a Backcountry a few weeks ago with E-Torque but now having second thoughts and thinking about changing the order to the standard Hemi without. After researching it more I’m just not sure E-Torque is for me.
I plan on adding an aftermarket exhaust that’s much louder than stock. Wondering how annoying the Start/Stop would be based on this. Seems it would be so much more noticeable in that case versus a quiet stock exhaust.I have the E-Torque and the transition from not running to moving again is seamless. The electric motor starts and you do not know it from the engine running and then transitions to the engine. The electric motor also make some of the shifts between gears much smoother. It is a very smart system. It also adds a bit of torque.
That's true, but you can disable it by installing an autostop eliminator. The button on the dash still works to enable it if you want, but when you turn it off with the button you won't have to turn it off every time you start the engine after that.I was under the understanding that Stop/Start could be permanently disabled by turning off but sounds like it needs to be turned off at each start up when driving….correct?
One question. How is this installed? Does it need to be wired in or just plug and play?Auto Stop Eliminator, there are coupon codes for 10% off.
Any pics would be greatly appreciated. Thanks.
Got it thanks. Easy as can be.Go on their website. It shows installation
I have the AWE with e-torque start/stop. You do hear it start but it's not like a cold start loud. You get used to it.I plan on adding an aftermarket exhaust that’s much louder than stock. Wondering how annoying the Start/Stop would be based on this. Seems it would be so much more noticeable in that case versus a quiet stock exhaust.
Like I said in an earlier post, I had eTorque in my 2019 and I liked it. I do not like it in my 2022 because of the fact that most of the time it shuts down the motor before it comes to a complete stop. Though I'm getting used to shutting the system off before I enter my garage, it's annoying that I even have to do this. My dealer is making a Star Case out of it so we will see what Ram says. Had I known that it was going to act this way I would NOT have gotten it. Now I feel I'm just carrying around the weight of a junk system that Ram ruined trying to increase their CAFE numbers. Change your order if you can.I ordered a Backcountry a few weeks ago with E-Torque but now having second thoughts and thinking about changing the order to the standard Hemi without. After researching it more I’m just not sure E-Torque is for me.
with an immediate 134 lbs-ft of torque, which the gas engine cannot do from a dead stop.
OK so, not that i'm one to disagree about a system I don't fully understand as i am not mechanical engineer, or a mechanic, but i understand what you just said even less5.7L’s BSG produces 49 lb-ft of torque.
The advertised 130 lb-ft is achieved through gear reduction.
