boogielander
- Jun 29, 2022
yes that's exactly what I'll be doing once my friend comes back from overseas to take my 4runner battery in to trade up.Are you planning on replacing your starter battery with an Antigravity LiFePO4 battery? I assume this because you mention a built in jump start button.
I’ve considered something like this, but I’m not sure how I’d tie a solar charger controller into the system.
when i ran the system in my 4runner it's just solar controller goes to the positive side of blue sea fuse block I installed and body ground.
so imagine this:
this is without solar controller (for simplicity)
starter battery->blue sea fuse block -> accessories
this is with solar controller (for simplicity)
starter battery <->blue sea breaker bar <->blue sea fuse block <-> accessory and solar controller
it basically turns into a two way street for positive currents to flow.
this is the one i use: Wanderer Li 30A PWM Charge Controller
Here's a quick video I made for someone else for a quick explanation of how i did it:
