My 2019 Limited lower halo on driver's side is out. At first it was not coming on when I start the truck in the morning, but after a while it was turning on on it's own. Now it is off all the time. I took the truck it to the dealer, they ask for $1700 to replace the entire headlight. Not fully trusting the dealer. Mopar warranty is not covering it.
Some hope that there maybe some loose wire, or bad connection somewhere on the headlight connectors. The headlight beams all work, upper halo works. Just bottom is out. Would appreciate if anyone has any ideas what to check or has some ideas how to fix it. I'm pretty technical and do most of my automotive work on other cars....this one still has Mopar warranty, but as mentioned light according to dealer is not covered.
Thank you all in advance!
