downsjh
I didn’t see much about DIY bedliner, so i thought I would share my experience.
I chose UPOL Raptor kit, black from amazon, $129. Removed tailgate , and the access panel from the tailgate. So I had the bed, tailgate, and panel to spray. Taped and covered everything in plastic due to overspray.
Sanded entire area with 80grit sandpaper. By hand, power tools seemed cumbersome due to curves and wanted to be sure just to rough the surface, and not removed paint.
Cleaned with TSP cleaner. Sprayed first coat, light. But still used first two bottles. Let dry 1 hour, then did second coat. Sprayed heavy on floor on bed, light on sides.
Looks awesome. Chose DIY to save money, protected from Arizona sun by Tonneau cover. May put down rubber mat to take it easy on my knees.
