DIY Spray Bedliner
downsjh
Tucson
I didn’t see much about DIY bedliner, so i thought I would share my experience.
I chose UPOL Raptor kit, black from amazon, $129. Removed tailgate , and the access panel from the tailgate. So I had the bed, tailgate, and panel to spray. Taped and covered everything in plastic due to overspray.
Sanded entire area with 80grit sandpaper. By hand, power tools seemed cumbersome due to curves and wanted to be sure just to rough the surface, and not removed paint.
Cleaned with TSP cleaner. Sprayed first coat, light. But still used first two bottles. Let dry 1 hour, then did second coat. Sprayed heavy on floor on bed, light on sides.
Looks awesome. Chose DIY to save money, protected from Arizona sun by Tonneau cover. May put down rubber mat to take it easy on my knees. IMG_0330.jpgIMG_0328.jpgIMG_0336.jpgIMG_0337.jpgIMG_0338.jpg
Looks like you did a great job! I've often wondered how that stuff will hold up and handle the sun. I personally put in the weather tech bed liner doesn't come up the bed sides but for a couple inches but alright for now.
Wow, you really did a professional looking job, Nice work!
I’ll give an update in a few months to how it holds up.
You did a great job! Why did you remove those panels from the tailgate? Did you spray them too but separately?
I removed the panel, so I could access the wiring for the camera and handle. 1. If I decide to modify anything that needs me to tap into the wires (bed lights, keyfob release, etc). 2. If something fails and needs to be reworked by dealer, they won't have to cut the screws and bed liner away.
Yes, I sprayrf the tailgate with a piece of cardboard instead of the panel, and spray the panel separately. Then reinstalled, still fit perfectly. Since screws are black, then don't stand out. Added 30min to the total time, so not a big effort.
That makes sense. I was just wondering and hadn’t thought about future access
Looks awesome. Chose DIY to save money, protected from Arizona sun by Tonneau cover. May put down rubber mat to take it easy on my knees. View attachment 32935View attachment 32936View attachment 32937View attachment 32938View attachment 32939
Magnificent job. Congrats!
I'm curious, did you tape off the holes in the bed and bed sides? I'm about to do a roll on liner myself.
No, I did remove the plastic caps( 2 on bottom left, 2 for bed light locations).
Holes didn’t shrink too much or fill in.
Used it for lumber, mulch and it’s held up well. Tonneau cover has protected from Arizona sun.
Haven’t tried it with anything harsher.
