Have you had the opportunity to drive both? You really should take the time to do so…ideally back-to-back.Was thinking along the same
You're most likely NOT going to recoup the upfront cost. If you like seeing consistent 25+ MPG on the highway (depending on weight of your right foot) and enjoy running a minimum of 750 miles per tank fill with the 33 gallon tank then the ED is your choice regardless of cost. As stated by others it's NOT going to be a rocket ship for passing or "flying" but it's no slouch either. I've never been afraid to pass with my ED's...it just takes a little more planning.I really appreciate everyone's inputs and assistance here. Truly. I was merely considering the ED over hemi due to fuel costs and range. Where I'm at fuel and diesel are neck and neck on prices. I realize there is a $2700 upcharge over the hemi according to the build sheet. I'm not sure how many "years" it would take to make that up either. I really like seeing 24mpg on my display too. The hemi I had was 15/19. Then 16 with the tires. I'm also looking at the Hemi with etorque to justify the hemi purchase.
Thing is in Arizona, everywhere is interstate mostly. I also usually keep trucks under 3 years as well. So I may not recoup that upfront expense. So maybe the hemi is a better option?
Range is definitely an advantage with the diesel. Especially if you get the 33 gallon fuel tank. It may not make sense for you to get one for the fuel economy if you're only keeping it 3ish years. But if you're looking for range you won't find a better option from a Ram 1500.I really appreciate everyone's inputs and assistance here. Truly. I was merely considering the ED over hemi due to fuel costs and range.
Apparently the ED wasn't enough for youIf you’re even considering the Ecodiesel just get it. If you don’t you’ll wish you had. IMO anybody who can afford a brand new truck shouldn’t worry about the price difference because it doesn’t really matter. Yes the Ecodiesel is more cost up front but it also has higher resale value too. I absolutely loved my Ecodiesel and if I ever go back to a 1/2 ton I’ll be getting another one. Gas mileage was incredible and if you change the oil yourself it’s not that expensive. I vote Ecodiesel all day everyday.
I needed more truck not more motor. I loved towing with that motor.Apparently the ED wasn't enough for you
You get 10k miles between oil changes. If you change it yourself it’s under $100. So even if you put 20k miles on a year you’ve got 2 oil changes and 1 fuel filter change which I also did myself so it cost $40 for the filter. If you spend 60k on a truck does $250 a year for oil and fuel filter changes matter?yeah, I've driven both, hemi 2020 and 2021 ED. I sold the 2021 for a Challener RT but miss my truck, so looking at ordering a 2022 rebel or Limited. the ED I had had the 3.92 gears as well. I guess I'm worried over expenses. I hear the ED's can be expensive over the HEMI in terms up routine maintenance. I don't know, why I ask.
yes the range is certainly nice in the ED. 600 miles with 3.92 gears is damn nice.
Dang, that's crazy.This is from someone who posted in the Ecodiesel powertrain forum on some pricing they got at a local dealer for maintenance. The ED is awesome but if your not going to service it yourself check your local dealers/independent shops for costs. The truck is already pricey and dealers/RAM make the cost to maintain it a nightmare. 10k mile oil changes are right at the limit depending on how you drive, i change usually around 7500 miles. Manual states to never exceed 10k. All the maintenance is easy but the oil filter is stupid expensive. Its not only the filter but the entire plastic assembly that holds it, $50 online at best and $100+ at dealer just for the part.
