Both the big horn level 1 and level 2 have the 8.4 inch Uconnect screens.Is the screen bigger in a level 2 than the 1? I thought they were both 8.5”?
The glossy finish’s is the 8.4 Uconnect with nav usually comes with the alpine system the matte finish is just the 8.4 uconnect with base six speaker system.Ok. And why does it appear that on the level 2 package, some come with a glossy finish and some have a matte finish? Is it just appearance or is there an actual difference in the packages?
8.4 nav, glossy finish, standard Big Horn radio level 2 package.The glossy finish’s is the 8.4 Uconnect with nav usually comes with the alpine system the matte finish is just the 8.4 uconnect with base six speaker system.
I have Level 2, wind buffeting is bad without the rear window open. That was at a speed of approximately 40-50 mph, have not experimented at various higher speeds.Spend the extra and get the 120V outlets and the bigger screen. The power rear slider also is real nice to get rid of the wind buffeting noise when driving with the window down.
Download the catalog directly from Ram it’s comprehensive
If you didn't order your truck you had to get the eTorque to get the Alpine system if you were buying stock off the lot. No eTorque meant base 6 speaker audio, at least it did when I bought mine.The glossy finish’s is the 8.4 Uconnect with nav usually comes with the alpine system the matte finish is just the 8.4 uconnect with base six speaker system.
Saw a lot of Big Horns and Laramies with no NAV (matte trim). It's a $795 option just to "upgrade" to a NAV unit (uConnect 4 to uConnect 4C NAV).8.4 nav, glossy finish, standard Big Horn radio level 2 package.
can someone tell me what features you’re not getting , if you were to get a Bighorn Level 2, with BTS package vs a Laramie.
You can put in LED bulbs easily. Not the same look as factory housings, though.I HIGHLY recommend getting LED headlight/tail lights!
That is my biggest regret about my truck.
