I want aluminum style - there is only one seller on amazon but is charging 4x the price. The regular aluminum ones are like $8 - and for 2020 Ecodiesel version they want $45 !
Amazon.com: Only for 2019 2020 Dodge Ram green diesel fuel cap. The aluminum fuel tank cap is magnetic. …: Automotive
Buy Only for 2019 2020 Dodge Ram green diesel fuel cap. The aluminum fuel tank cap is magnetic. …: Fuel Tank Caps - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Its all chinese made stuff - sooner or later its going to pop up everywhere for the same cheap price.
there's more than one page... how many threads are you going to start?
What does it look like underneath the top? The other side of it.The Mopar one is nice. It's nothing fancy but very functional. You can it here.
It's like a flexible plastic. Snaps on tight and doesn't moveWhat does it look like underneath the top? The other side of it.
No rubber seal though. Dirt can still get in, how could this design possibly be an improvement?It's like a flexible plastic. Snaps on tight and doesn't move
Because it's like a rubber plastic and it covers the entire opening of the fuel port. It goes around the outside of it and seals it. No need for a rubber seal.No rubber seal though. Dirt can still get in, how could this design possibly be an improvement?
Get the $10 billet aluminum amazon ones with the magnet.
Amazon.com: HKOO Diesel Fuel Cap for Dodge, Billet Aluminum Green Fuel Cap Magnetic and Blue DEF Cap for 2013-2018 Dodge Ram Truck 1500 2500 3500 with Easy Grip Design (Standard Grip): Automotive
Buy HKOO Diesel Fuel Cap for Dodge, Billet Aluminum Green Fuel Cap Magnetic and Blue DEF Cap for 2013-2018 Dodge Ram Truck 1500 2500 3500 with Easy Grip Design (Standard Grip): Fuel Tank Caps - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I got a 2020 longhorn with the 3 ribs and it works juuuuust fine.Like I mentioned above, this one DOES NOT work with new body-style 2020 EcoDiesels - guess how I know that ? Because I have this green one for sitting in my garage. It*MAY* work for classic body style trucks, but not the new body style - it has updated filler neck for diesel , with 3 ribs. Following is the picture from amazon - and thats why they want $45.
Again same item (like the one I ordered) is $10 but would not fit newest trucks - gotto pay 4x more.
Amazon.com: Aluminum Blue DEF Cap Cap, Non-magnetic Blue DEF Cap for 2013-2018 Dodge Ram Diesel Trucks 1500 2500 3500: Automotive
Buy Aluminum Blue DEF Cap Cap, Non-magnetic Blue DEF Cap for 2013-2018 Dodge Ram Diesel Trucks 1500 2500 3500: Fuel Tank Caps - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Went with this one. It's the best option to stop dust or water from entering, doesn't seam like any of them seal .Because it's like a rubber plastic and it covers the entire opening of the fuel port. It goes around the outside of it and seals it. No need for a rubber seal.
The Amazon ones rely on sealing on the inside and there is a potential for grit to fall in once you remove the cap. The Mopar one covers the entire thing.
Its just like your windshield washer fluid cap, but green and $50 for 3¢ of plastic.I have the metal one from my 2016 and it worked on my 2020. Not sure you get the same o-ring fit due to the ribs on the truck side. Would be curious what the bottom side of the $40 dollar one looks like, does it seal better or similar too my old one?
