I just picked up a 2019 Ram Classic SLT Lonestar V8 Hemi with 11K miles. I have been "researching" flat-spotting on cams known to occur on older Hemi V8 generations and seeking whatever preventative measures I can to avoid replacing cam/rollers and whatever else in the future. A lot of debate on the Hemi "tick" issue is all over the web that tries to pinpoint the cause. The general consensus on that issue suggests that the bearings in the cam rollers are faulty and can "stick" thus wearing down the cam lobes leading to one of two Hemi "ticks" (faulty exhaust manifold bolts being the other issue). Some sources have suggested that deactivating the MDS combined with upgrading to full synthetic 5w20 (while under warranty) is a good one-two punch to avoid this serious problem (mechanics have reported that affected cams and cam rollers have been oil starved and a synth could help. Some folks have even suggested switching to 5w30 after the warranty has expired).
Alternatively, another source has stated that in 2016-2017, Chrysler addressed this problem (though he did not expand on what was done). The mechanic that discussed this issue stated that he had not seen any Hemi v8 MDS equipped models in his shop that had problems related to flat-spotting on cams or issues with cam rollers. He did admit that it is conceivable this problem is not widespread yet on 2017+ models because mileage on those trucks should still be fairly low after 3 years f use. However, I have seen on message boards where owners have had this issue happen as early as 25K miles on older models.
So a few questions here.
1. Did Chrysler address the cheap cam roller issue or do something to fix the flat-spotting on cams at some point?
2. Because 2019+ models are "5th Gen", is the Hemi tick/cam flat-spotting still something to be expected?
2. Has anyone experienced the Hemi tick in a 2019 or 2020 model and if so, what was the diagnosis? Is the Hemi tick alive and well?
3. What are your thoughts on disabling the MDS to prevent this problem in case Chsyler has not fixed this issue? (FYI, disabling the MDS is pretty easy and can be done one of two ways and does not void warranty)
