Deploy side step puzzle
MSgt Van
South Central Minnesota
My 2019 Limited had always deployed the side step when door was opened, and then retracted it after all doors were closed (step programmed to auto deploy).
Yesterday early a.m. I was putzing with deploy/retract button under controls menu. I closed the menu and went about my day. I noticed that the step would then deploy when I put the truck in park and they'd stay out until the truck was put into gear. They'd stay deployed when the truck was off. Not sure what I did, but today they're working as in the past. Did I fumble on a super-secret button push or something yesterday? Can't find anything in the manual. I kinda liked the "new" mode.
Trippi
Macedon NY
not sure if I am following you correctly but when i want the side steps to stay deployed...I put the truck in Park and then hit the powerstep button in settings. turn the truck off and get out...steps stay deployed until i get back in the truck and hit the button again.
Darksteel165
Massachusetts
Sounds like the door sensor went.
Are the lights staying on?
When you move or shut the door the steps will retract
There is also a stow button to keep them in, and another button to manually deploy them.
MSgt Van
Thanks for that tidbit of intel. I'll see if that recreates what I was experiencing.
