So I successfully screwed up my truck today swapping out my upstreams O2s. Passenger side went fine, but I couldn't for the life of me get the driver's side wiring to disconnect. I inadvertently, pulled a little too hard and pulled the main harness four pins from the connector. It's such a tight area to work in and I've been unable to fully seat them back in the connector. I called around to a few repair shops and they said I probably broke the clips because the pins should easily go in and just lock in place.
Now I've got a CEL and had to order a new full engine harness at $400. Once that comes in, it'll probably be about 5 hours of labor to pull the old harness and replace with the new. Add another $800 for labor and, what should have been a simple O2 swap is now a $1200 repair.
