Daystar 1” front spacer
Jtimm07
466C2AB2-1F63-4C9B-885D-0F1F9C3F9D19.pngHas anyone tried these in their trucks?
I have a 2020 Laramie Sport with ORG and I’m wondering if these would work.
Any info is appreciated, Thanks
129 for those seem way too pricey. ive seen other kits similar with 2 inch that are less than a hundred. It says for the DT so it'll work. 1 inch isn't to crazy of a difference and guys have luck with the 2 inch spacers so with your ORG you should be fine
That looks like a pre-load spacer. Maybe at 1" its not too bad but I believe Top Hat spacers are preferred over pre-load spacers.
Just looking for a way to get 1” up front ... had lifted trucks in the past and liking the stock height and want just the 1” rake so I don’t want to go to a 2” to level. This the first thing I’ve seen in between a 1/2” and 2” so I was wondering if anyone has tried it that has the ORG springs and what the ride is like and if you like it.
