Noticed a good number of 2019 Crew Cabs locally that have the 6'4" bed and got wondering what bed lengths those of you with Crew Cabs have or ordered. Is it the 5'7" or the 6'4"? That is one mighty long truck with the 6'4" bed.
5.7 bed for me also. most of the crew cabs i see on lots or out on the road are the 5.7 bed. by now they look normal to me plus i get plywood or 2x4's with no problems.
I don't think so but wanted to mention the misleading image on Ram.com on the capability page, I believe. They have a shot from above of a sheet of plywood in a RamBox 5'7" bed that doesn't hang over the tailgate. If you look at the gridlines printed on the plywood, you can see the 4' length mark (square if you cut the plywood in half) but now you can also see there is not half a sheet left. They cut the plywood to make it fit thus implying a sheet will fit and not hang over.Can you fit a 4x8 sheet of plywood flat in the bed without overhanging the tailgate?
boy, you're testing my old brain. i think it is even with the tailgate or hangs over just a bit. i always secure with some straps and never had a issue. had 3 rams and 1 tundra with this bed.Can you fit a 4x8 sheet of plywood flat in the bed without overhanging the tailgate?
you think they figured out yet where they rank with you??The shortbox was for my wife's benefit more than anything else as she will drive it occasionally. Regardless, it'll sit outside 24/7......sun, rain, hurricanes..... My garage has a 2016 Corvette and a 1969 Camaro SS in it. My Jeep and truck spend life outside.
