JakeHagg25
- Feb 15, 2019
So, to start off, let me explain why I did it. I purchased the Reflective Concepts stickers for the front emblems, and they didnt have the color to match the Delmonico Red of my truck so I ordered red and thought the worst case scenario, It looks like garbage. To no surprise to me the bright red lettering looked awful next to my dark red paint, so I removed it, as I was removing them I noticed that the '0' in '1500' was wiggling independent of the rest of the emblem I took a look at my spare emblems and noticed that they definitely are an independent entity to the rest of the emblem, and so I got thinking.
Here is a picture of the emblem stock.
The little pin near the head of the screw driver is what holds the numbers in place, I just took a larger flat head and push the peened end until it snapped off, then I could use the small
screw driver to easily pry the numbers off.
I used my spare hood emblem to test the painting because if it didn't work I still had the Emblems still on the truck. But thankfully all the pins are the same so once I painted the chrome numbers I could throw them onto the black emblem.
Started off by sanding with 150 grit to rough up the surface and make sure I got good adhesion.
I used a sanding block and a piece of sand paper rolled up to get the nooks and crannies of the pieces.
Next came the primer, two light coats to completely cover the part but without getting runs.
I had to paint the numbers twice because the first color I chose was not as close of a match as I thought, of course this was after I had already painted it and cleared it, so I was a bit bummed. This is the color I had to work with since no auto parts store carried Delmonico Red spray cans, I originally tried " Dark Garnet Red Metallic", THAT IS NOT THE CORRECT COLOR, pictured below is the final color I ended up using. "Medium Garnet Red Metallic", Its a GM color but it was pretty close.
Continue...
Continue...
