Check engine light
Sascwatch
Truck wouldn’t remote start this morning, figured it was a distance issue but it wasn’t. After starting the truck I’ve got a check engine light on, called Uconnect through the truck and I guess they can’t see codes remotely??
Booked to see the dealer today at 1:00.
Restarted the truck after running a few errands and the light is off now, not sure if the dealer will be able to see what the issue was.
Alright so after waiting for close to 2 hours the tech found a broken/damaged wire leading to the lift pump. I tried several times to get the code that was stored but got nothing, not even paperwork for the repair.
I will be taking a good look under the truck when the weather is a bit nicer to see if I can find the repair.
