Center console phone holder pad removal/replacement?
rubrduk
I was installing the brake controller and had the sides of the console protected but did not realize I was gouging the rubber phone holder pad before I had done the damage.
How do you remove it to replace it? Can it be removed without completely removing the console?
All I can find right now is the wireless charger but you can check with Moparwholesaleparts.com
You can add to your truck or pay close to the same for non wireless cover. I installed myself on my 2019 to wireless charger. My limited came with it.
Try to get a black rubber cleaner if you want to try and save some money. I recently threw my old one in the trash otherwise I would have let you have for free.
I'll give it a shot
Usually i'm good about protecting the parts and trim, but this one got me
any idea what it's called or even a part number so I can find a replacement?
I might like to have the old part if you replace it, and if practical to ship or pick up. I want to mount an amateur radio transceiver, and would be cutting that part out.
You might try some heat. A hair drier or heat gun. I wouldn’t do it for long or get too close. Make sure to keep it moving. Might be worth a shot.
