Cause of loud low frequency noise above 1500rpm in Drive?
RAMet5.7
Just got this 2021 RAM 1500 and after 300 miles got a loud low frequency (like a jet engine) noise above 1500-2000 RPM in drive.
flip to neutral and it goes away no matter the rpm
Doubt it is ANC, radio is off.
Any ideas?
Scap
Any ideas?
ANC is always on unless a window is open.
Try opening a window and see what happens.
theblet
You can unplug the amp under the drivers seat to disable ANC also. Try that and see what it does
RamCares
Michigan
We regret to see that you're having these concerns with your truck. If you're thinking of having this looked at by your dealer, let us know. We're available via direct message and can help with this process.
Callie
Ram Cares
